Guest Katydid Posted April 6, 2007 #1 Posted April 6, 2007 Does anyone know of a source for generic handlebar mounted switches for accessories? Thanks, Dave
Eck Posted April 6, 2007 #2 Posted April 6, 2007 Is this what you mean , or is this what you are looking for in an accessory switch?? If so, check JC Whitney..
Guest Katydid Posted April 6, 2007 #3 Posted April 6, 2007 YES thats what I'm looking for...I didnt see these on the JCW website, but I'll go look again. Thanks, Eck
Tartan Terror Posted April 6, 2007 #4 Posted April 6, 2007 If you want black this is from JP cycles. http://www.jpcycles.com/productgroup.aspx?GID=3142C9E1-A621-49FF-8C17-D45A222B0955 Or this. http://www.hellrisercustoms.com/selector.php?group=7&category=Handlebars&subcat=Brakes&title=Handlebar
Guest scooter38 Posted April 6, 2007 #5 Posted April 6, 2007 I bought mine from http://www.CruiserCustomizing.com thought I rewired it and put better switches on it too, cause the way it is all three switches are hooked up from one power wire.
Guest Katydid Posted April 6, 2007 #6 Posted April 6, 2007 Thats exactly what I needed...thanx, Scott(s) for the links. Dave
Leland Posted April 7, 2007 #7 Posted April 7, 2007 www.bigbikeparts.com has the switch for the left side (clutch).
Guest Katydid Posted April 7, 2007 #8 Posted April 7, 2007 Bigbikeparts website is under construction
Carbon_One Posted April 7, 2007 #9 Posted April 7, 2007 I have one from JCW too. Mounted it over the clutch resvoir. No power going thru the switches thou. I have it wire stricly as a grounding switch for the relay running the low beam headlight, spots , and bullet gauge lights Larry
