sgn Posted June 28, 2008 #1 Posted June 28, 2008 Any one have advise on how to push up the air joint bracket to remove the spring wire clip so that the fork leg will drop down (shown manual page 5-30) If it just pushes up it must take a 500 pound ape - cause mine won't move Thanks all
Rocket Posted June 28, 2008 #2 Posted June 28, 2008 Any one have advise on how to push up the air joint bracket to remove the spring wire clip so that the fork leg will drop down (shown manual page 5-30) If it just pushes up it must take a 500 pound ape - cause mine won't move Thanks all The O rings inside stick pretty good, I use a brass drift & hammer to tap them up and off (from below).
sgn Posted June 28, 2008 Author #3 Posted June 28, 2008 wiil get a little more forceful in the morning, I was afraid I was missing something
Squeeze Posted June 28, 2008 #4 Posted June 28, 2008 Spray something like WD 40 on the Fork Legs, let it sink for a while and turn the Rings to left and right before prying them off. Once you got them moved, they will come up easily.
sgn Posted June 29, 2008 Author #5 Posted June 29, 2008 Thanks guys ....Sprayed with Crud Buster, left sitting for a few minutes.A section about 1 foot long of 1" sch. 40 pvc from uderneath and 1 tap with hammer did the deed
