Joopster55 Posted June 26, 2008 #1 Posted June 26, 2008 Is there a way to adjust the rear brakes on a 2nd Gen? I've checked my manual and searched here, I can't find anything on rear brake adjustment. When pushed on, my brake pedal goes right to the bottom with very little braking. I've checked the pads, lots of pad left. Only have 10,700 kms on them. Thanks in advance.
Billet Posted June 27, 2008 #2 Posted June 27, 2008 Sounds to me like it's time to bleed them. And check for leaks!
M61A1MECH Posted June 27, 2008 #3 Posted June 27, 2008 No adjustment except the fluid level. Have you checked the fluid level? Could be it is low and you have gotten some air in the system, if so you will need to bleed it to get the air out. Could be the fluid got contaminated with moisture which could make it less effective than it should be.
