Numb Knuckles Posted June 26, 2008 #1 Posted June 26, 2008 I made a quick carb air screw tool by flattening the end of a pc. of 5/32" x 4" welding rod and bending it in the middle to 90 degrees so that now I can adjust the front carb screws without having to remove all of the blasted plastic. Gary:farmer:
Dano Posted June 27, 2008 #2 Posted June 27, 2008 Where's the pics??????!!!!!!! Number 1 rule around here!!!!! Dan
Numb Knuckles Posted June 27, 2008 Author #3 Posted June 27, 2008 Never done this:fingers-crossed-emo B4. Hope it works.
Cutty Posted June 28, 2008 #5 Posted June 28, 2008 Numb Knuckles said: I made a quick carb air screw tool by flattening the end of a pc. of 5/32" x 4" welding rod and bending it in the middle to 90 degrees so that now I can adjust the front carb screws without having to remove all of the blasted plastic. Gary:farmer: I like to look at that screw when making a sensitive adjustment such as that is ( just my 2 cents ).
greg_in_london Posted June 28, 2008 #6 Posted June 28, 2008 I just ground off the end of a mortice lock key and made it into a screwdriver. It's a good fit and I can see how much the head turns much better than I would be able to see the screw.
