Just wondering where is all the wiring on the RSVTD that is in the upper fairing on the RSV? The radio/player is obvious - so the TD does not have intercom & cruise and what else? Anyone know?
The wiring harnesses are totally different, front to back to top to bottom. The RSTD does have cruise, but the power switch is on the RH switch box instead of on the dash. So the RH switch box is different. So is the left one - no talk switch. And it's more than just leaving out two wires. Even the connectors are different. The main cut off relay is not even the same thing. The main connections are made in the headlight bucket.
