Iowa Guy Posted June 17, 2008 #1 Posted June 17, 2008 So, I have painted 3 coats of black over the factory red paint, lightly sanding between coats and am now ready to spray a clear coat on. Do I lightly sand again between the clear coat layers? Iowa Guy (first time painter)
Thom Posted June 17, 2008 #2 Posted June 17, 2008 yep , makes each coat stick better and it helps keep a smooth finish Thom
Brake Pad Posted June 17, 2008 #3 Posted June 17, 2008 if your in a dusty garage, spray the floor down with water, keeps the dust from flying into your finish
Docdet Posted June 21, 2008 #4 Posted June 21, 2008 Duplicolors makes a flake spray you can spray inside the clear,,, really looks nice in the light
