21 minutes ago, RDawson said:
Depends if you measure it before or after you crush it.
 Pre-crushed would probably make it easier but can't find any on Amazon. 😁
Measure the banjo bolt diameter, then measure the OD of the boss the washer sits on and you will have your size.  I did look up the part and sizes are not given because Yamaha wants you to buy their stuff rather then provide useful information.
You could always buy the assorted sizes for $10.00 versus the $5.37 Yamaha wants for each washer and have a lifetime supply.
https://www.amazon.com/LordHardware-200pcs-Sealing-Washers-Assortment/dp/B08SHYWDFK/ref=asc_df_B08SHYWDFK/?tag=hyprod-20&linkCode=df0&hvadid=693270340278&hvpos=&hvnetw=g&hvrand=9307670490974978852&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=1026758&hvtargid=pla-1416628693137&psc=1&mcid=dbba1e24d90e305aa71412027c632def
