VentureFar Posted September 10 #1 Posted September 10 I was cleaning the bug guts off the front of my 2007 RSV and found my left wind deflector hanging loose. Nuts and bolts still attached. I took the plastic off for better access to the bracket. I discovered that several years ago I replaced one of the two bolts that hold the bracket as they were 5mm and 4 mm. What tool (Allen head obviously) will fit up in that small space and allow turning and tightening ? I don’t want to cut the head off my t- handle Allens to turn it with a spanner any tool suggestions ?
Marcarl Posted September 11 #2 Posted September 11 I have a miniature tool kit with short bits and a small driver handle. Kit has many different bits in it. Harbour Freight or Princess Auto.
luvmy40 Posted September 12 #3 Posted September 12 This little kit from Harbor Freight is "The Mott's"! https://www.harborfreight.com/locking-flex-head-ratchet-and-bit-set-35-piece-58074.html?_br_psugg_q=icon+wrench+set
Du-Rron Posted September 13 #4 Posted September 13 @VentureFar, I have enjoyed using these. Click Here for Wadsworth Tools. 20240912_205324.mp4
