Precious Posted July 29, 2024 Posted July 29, 2024 Has anyone tried a spray sealer for stopping air intake leaks on a v4? If so, which one do you use? I suspect I'm going to have tear the carbs down over winter and likely replace the rubber at that time, but would really like to get the rest of this season in. Thoughts? Ideas? Much thanks
Precious Posted July 30, 2024 Author Posted July 30, 2024 I can't tell, but they look okay. I used carb cleaner to test and all responded with increased RPM.
Marcarl Posted July 30, 2024 Posted July 30, 2024 take a close look at the boots to make sure they are properly seated. Look all around and then look again, you'll need a light. Check both top and bottoms. They can be a pain to seat 100 % proper.
