mike042 Posted July 24, 2024 #1 Posted July 24, 2024 2011 RSV I'm changing the seals in rear brake caliper, are there 2 different sizes of the 4 pistons? I was ordering the seal kits from partzilla and seems to be two different part numbers.
Marcarl Posted July 24, 2024 #2 Posted July 24, 2024 I only see one kit. Cheaper at: https://www.yamahasportsplaza.com/oemparts/a/yam/5004d6cef87002275461d662/rear-brake-caliper
Marcarl Posted July 24, 2024 #3 Posted July 24, 2024 4 minutes ago, Marcarl said: I only see one kit. Cheaper at: https://www.yamahasportsplaza.com/oemparts/a/yam/5004d6cef87002275461d662/rear-brake-caliper On a second look, there does seem to be 2 numbers that are needed to complete the rebuild. Somebody more knowledgeable needs to chime in here.
BratmanXj Posted July 24, 2024 #4 Posted July 24, 2024 There were Inner & Outer seals on mine, but its been a few years since I've been in there. I bought a complete rebuild kit from All Balls when I did mine https://www.allballsracing.com/18-3194.html 1
Marcarl Posted July 24, 2024 #5 Posted July 24, 2024 6 hours ago, BratmanXj said: There were Inner & Outer seals on mine, but its been a few years since I've been in there. I bought a complete rebuild kit from All Balls when I did mine https://www.allballsracing.com/18-3194.html There you go! Good answer!
mike042 Posted July 26, 2024 Author #6 Posted July 26, 2024 Yes I know there are 2 seals on each piston. I ordered 1 of each part number, they just came and matching them to each other they look identical. So I don't know why the numbers are different but at least I have all the seals I need . Just another mystery of partzilla
Marcarl Posted July 26, 2024 #7 Posted July 26, 2024 The one seal would be grooved, the other I think is flat. Grooved to the outside.
