Rcoon Posted July 24, 2024 #1 Posted July 24, 2024 Greeting all, I just purchased an ‘09 RSV 38k miles, and would like to put OEM mufflers back on. It currently has some sort of aftermarket straight pipes, not my thing. I understand the carbs should have been rejeted when the current pipes were installed. I called the authorized Yamaha repair shop and they said $1200 to check if they need to be rejeted but if the carbs need to be replaced it will be more. Not sure why they would need to be replaced. also if anyone has a contact for a competent Yamaha tech in northern Florida please send me them my way. Thanks
Marcarl Posted July 24, 2024 #2 Posted July 24, 2024 Personally I would just put the OEM pipes on and then go from there. The PO might not have re-jetted.
Rcoon Posted July 24, 2024 Author #3 Posted July 24, 2024 Thanks for the response, you may well be correct, found the old maintenance records which indicates when the Samson Turnout exhaust was installed ($90) but no mention of rejet. Only later was a set of needle valves ordered. My understanding is needle valves are for the floats. I think I’ll take your advice and install OEM and go from there, thanks Marcel!
BratmanXj Posted July 24, 2024 #4 Posted July 24, 2024 I know a lot of us here have put a Harley touring muffler on our bikes with no change in carburation... I agree that you can probably go back to stock mufflers without an issues.
Justme1939 Posted February 9 #5 Posted February 9 Hey there! I just picked up a 2006 venture with 11500 miles on it.been working on her and got it running not bad but it's popping and idling high.idle adjuster is not even touching. It was a theft recovery and some parts were missing and/or wrong.Can someone who is versed in these bikes give me some ideas please as I normally work on harley davidsons. Thank you
Marcarl Posted February 9 #6 Posted February 9 1 hour ago, Justme1939 said: Hey there! I just picked up a 2006 venture with 11500 miles on it.been working on her and got it running not bad but it's popping and idling high.idle adjuster is not even touching. It was a theft recovery and some parts were missing and/or wrong.Can someone who is versed in these bikes give me some ideas please as I normally work on harley davidsons. Thank you Best to start a new thread if you want answers quickly.
