Francois Posted April 30, 2024 #1 Posted April 30, 2024 Here i have a royal star venture 1999 and when i bring back my horse at home after winter storage i see no low beam but high beam are ok so i change the bulb cause i'm sure it was blown but even a new one has no low beam but high beam are ok , i'll verify wires - switch - earth of bike - corrosion not present and everything are ok then i think about relay are blown somewhere but don't know which one and where it located neither if rsv has this kind of relay so i request help here, I'm not a mecanician so if i can fix my own motorcycle i think it's the best way to knew it Thank's in advance
BlueSky Posted May 2, 2024 #2 Posted May 2, 2024 Take a good look at the bulb to make sure it's ok. I installed a Sylvania Ultra, the bightest, and it burned out in seconds. both low and high beam. So, I replaced it with the base bulb and it worked fine. 1
