BratmanXj Posted April 23, 2024 #1 Posted April 23, 2024 After a year a miscellaneous down time with stator & electrical gremlins, the time sitting has taken its toll on my fueling system. My '99 is missing on 1 cylinder, I've done the heavy dose of cleaner into the tank a few times and even direct injecting it into the carb bowl with no real help. So I think its time to pull the carbs and give them a good cleaning. With that, I have a few questions 1. Anyone done the Ivan's Performance Kit (Ivan's XVZ1300)? I know his fuel injection re-maps are well regarded, and since I'm already in there it might not be a bad idea since I have K&N filters & Harley SE Mufflers that could probably use a slight boost in fueling. 2. I know the gaskets are supposed to be reusable, but I question 25yr old rubber parts coming apart nicely. I did find Service Kits available (XVZ1300 Mikuni Service Kit) and while the DellOrtoShop shows US, its all based off a Netherlands company. Does anyone have known good place to buy genuine (not chinesium) parts?
BlueSky Posted April 24, 2024 #2 Posted April 24, 2024 Why not do a compression test just for fun to confirm the health of the engine.
BratmanXj Posted April 24, 2024 Author #3 Posted April 24, 2024 I've already pulled compression, checked spark & changed plugs and narrowed it down to a fuel delivery issue before posing the question for parts here. 1
Du-Rron Posted April 24, 2024 #4 Posted April 24, 2024 @BratmanXj try https://dealer.klsupply.com/carb-fuel/carb-fuel-products.asp
