RDawson Posted March 25, 2024 #1 Posted March 25, 2024 Seems like every spring somebody posts a reminder to check fluids, tires, pressures etc. Handling on my bike seemed to get loose last fall, and I really didn’t look into it past tire condition and pressure, rode it last week and it didn’t ride well at all. I finally started looking at it and figured out 0psi in the left fork vs 6psi in the right makes it unhappy(bad Schrader valve core). I ordered new Sonic springs and fork oil to solve this problem permanently. Moral of the story: Don’t be complacent and do a better job pre tripping your bike than I’ve been doing. Easy to get lazy on a bike that rarely shows a problem. 1
Woody Posted March 25, 2024 #2 Posted March 25, 2024 True that, I kept using the battery in mine last year knowing I needed to replace it so last week I put the new battery in getting ready for riding season, so I have changed the oil and filter, checked all tires, new battery and checked lights. I need to check the brake and clutch fluid condition incase it needs flushing. 2
Freebird Posted March 26, 2024 #3 Posted March 26, 2024 I think you will like the Sonic Springs. In my opinion, they are the best option for the RSV. 1
RDawson Posted March 26, 2024 Author #4 Posted March 26, 2024 1 hour ago, Freebird said: I think you will like the Sonic Springs. In my opinion, they are the best option for the RSV. They were your idea anyway 🤣. I’ve got some pretty strong front dive after 80k on it. I started reading posts here thinking about progressives and found several posts by you and Rick Butler about the Sonics. I placed the order yesterday, when they get here I’m going to install them in a lower mileage set of Midnight forks from a parts bike I bought. Hopefully having the forks ready will make a quick job of pulling the fairing and swapping forks. I already have a hook in the ceiling to hang the inner from doing head bearings a couple years ago. I saved them with the idea of liking the chrome forks someday. 3 1
ragtop69gs Posted March 27, 2024 #5 Posted March 27, 2024 Ron, i installed sonic straight rate springs along with 15 wt fork oil, and I now run 0 psi air in the forks. I love the ride now. 1
ragtop69gs Posted March 31, 2024 #6 Posted March 31, 2024 Rick was a huge help when I did my forks. I replaced all the bushings in the forks while I was in there. I do remember using some well casing PVC pipe as spacers to set the spring pre-load, I can't remember what length I cut them to. I had a long conversation with Cowpuc about setting the sag/preload, it was a long time ago and I don't recall the specifics.
