M61A1MECH Posted November 16, 2023 #1 Posted November 16, 2023 I just wanted to raise some awareness for the newer members and remind some of the older members that I still build and sell the items in the links below. Even though sales have dropped off over the years I still maintain stock of most parts and I can normally build and deliver within two to three days. If you have a special need for adding additional lighting, I most likely would be able to help out either with parts or directions. https://www.venturerider.org/forum/forums/topic/62637-5-wire-plug-n-play-trailer-harness/ https://www.venturerider.org/forum/forums/topic/62638-4-wire-plug-n-play-trailer-harness/ https://www.venturerider.org/forum/forums/topic/62635-aux-lighting-harness-for-tour-deluxe/ https://www.venturerider.org/forum/forums/topic/62636-runturnbrake-light-bar-for-2nd-gen-ventures/ https://www.venturerider.org/forum/forums/topic/62634-aux-lighting-harness-for-2nd-gen-venture/ I also build trailer adapters for the Eluder and Transcontinental and adapter harnesses for adapting the lighting on Harley type tour-packs that are added to the Eluder. 1
etcswjoe Posted November 16, 2023 #2 Posted November 16, 2023 You make GW stuff as well, if I remember correctly
M61A1MECH Posted November 17, 2023 Author #3 Posted November 17, 2023 On 11/16/2023 at 11:07 PM, etcswjoe said: You make GW stuff as well, if I remember correctly Expand In deed I do make trailer set ups and other small connection items as needed. Thanks for reminding me, I forgot to post that bit.
luvmy40 Posted November 17, 2023 #4 Posted November 17, 2023 For any of the newer members: Steve's products are high quality, easy to install and his technical support is top notch. Don't hesitate to purchase from him if he makes what you need. 1
RDawson Posted November 17, 2023 #5 Posted November 17, 2023 On 11/17/2023 at 10:58 AM, luvmy40 said: For any of the newer members: Steve's products are high quality, easy to install and his technical support is top notch. Don't hesitate to purchase from him if he makes what you need. Expand Yeah, what he said. I also use some of Steve’s wiring. Plug n play quality stuff. 1
