I just wanted to raise some awareness for the newer members and remind some of the older members that I still build and sell the items in the links below.
Even though sales have dropped off over the years I still  maintain stock of most parts and I can normally  build and deliver within two to three days.
If you have a special need for adding additional lighting, I most likely would be able to help out either with parts or directions.
https://www.venturerider.org/forum/forums/topic/62637-5-wire-plug-n-play-trailer-harness/
https://www.venturerider.org/forum/forums/topic/62638-4-wire-plug-n-play-trailer-harness/
https://www.venturerider.org/forum/forums/topic/62635-aux-lighting-harness-for-tour-deluxe/
https://www.venturerider.org/forum/forums/topic/62636-runturnbrake-light-bar-for-2nd-gen-ventures/
https://www.venturerider.org/forum/forums/topic/62634-aux-lighting-harness-for-2nd-gen-venture/
I also build trailer adapters for the Eluder and Transcontinental and adapter harnesses for adapting the lighting on Harley type tour-packs that are added to the Eluder.
  • Like 1
10 hours ago, etcswjoe said:
You make GW stuff as well, if I remember correctly
In deed I do make trailer set ups and other small connection items as needed.
Thanks for reminding me, I forgot to post that bit.
For any of the newer members: Steve's products are high quality, easy to install and his technical support is top notch. Don't hesitate to purchase from him if he makes what you need.
  • Like 1
Yeah, what he said. I also use some of Steve’s wiring. Plug n play quality stuff.
  • Like 1
