BillyJackC Posted October 14, 2023 Posted October 14, 2023 The computer lights up but can’t adjust and have never heard it run
luvmy40 Posted October 14, 2023 Posted October 14, 2023 (edited) It doesn't do anything automatically. You have to have the key in the accessory position and tell the system to pump to a preset or manually set a pressure. Always work front tire first. If you see an error code, you likely need to re-solder the connector pins on the circuit board. It's a relatively easy job. Edited October 14, 2023 by luvmy40 1
