3/4 of my instrumentation lights are blown. I can see the tach at night but that’s it. Can you explain how to access these lights? Do I need to remove the dash assembly to replace the blown lights? Thank- you,
Mark
  • DonnyRudeDude changed the title to Replacing Instrumentation Lights
Ok, Pasta Burner, thank-you. I have a VR parts bike I may practice on before I attempt it. I've seen on You Tube where the instrumentation panel is removed to fix the howling speedometer so I'll follow that process and lube the speedometer while I'm at it,
Mark
Mark
I did grease that speedo, and the cable. Wonder what is causing that now. Special tool needed for the speedo.
Hi Carl, the 84 VR is running great (Thank you) I was referring to my 86’. I lubed the cable but no effect. I was hoping to see you on the Ontario ride to pick your brain on this one.
Mark
Mark
You need a cable lube tool, and then you have to get at the back of the speedo to use it for it's purpose.
