A hose to the ear moved to various places on the engine may locate the sound better.  Or even remove the valve cover to see if it's valve related.
  • Like 1
Pretty much sounds like bottom end rod knock to me. Chances are good crank is pooched as well. Top end would normally have more of higher pitch tapping sound versus a heavy knock. I would probably look for a good used engine rather than spend the time and expense of rebuilding. Drain the oil into a clean container and see what comes out with the oil.
