Pasta Burner Posted September 24, 2023 Author #3 Posted September 24, 2023 (edited) It got a bit chilly overnight but the right mummy bag did it’s job. Met at a Harley shop in Logan Ut. who supplied an awesome breakfast. Did an organized ride with the Vagos up to Preston Id for a day of motorcycle rodeo, food trucks, raffle, live band, camping and of course drinking among other things. Great time! My first moto camping. Edited September 24, 2023 by Pasta Burner 1
BlueSky Posted September 24, 2023 #4 Posted September 24, 2023 (edited) It's great to see some Gen 1s in the wild! Edited September 24, 2023 by BlueSky 1
Pasta Burner Posted September 24, 2023 Author #5 Posted September 24, 2023 (edited) Beautiful morning too. Letting off some overnight chill Edited September 24, 2023 by Pasta Burner 2
Pasta Burner Posted September 27, 2023 Author #6 Posted September 27, 2023 Interesting thing I wanted to ask about…my bike sometimes has struggles to start mainly because I need to do some maintenance on the choke. In the cold morning my buddy was like good luck getting her running, to everyone’s surprise half a crank and she purred like a lioness. Left it idling for like 1.5 hrs charging my phone and packing up. Shut her down to access the key and the battery didn’t have enough juice to kick back over. What would cause this? Weak stator? I did in hindsight also have the heated grips running, and playing music. 1
Woody Posted September 27, 2023 #7 Posted September 27, 2023 Sounds like at an idle it wasn't producing as much as was being used, heated grips use a lot of current
Pasta Burner Posted September 27, 2023 Author #8 Posted September 27, 2023 1 hour ago, Woody said: Sounds like at an idle it wasn't producing as much as was being used, heated grips use a lot of current That’s exactly what I wanted to hear!
BratmanXj Posted September 27, 2023 #9 Posted September 27, 2023 1 hour ago, Woody said: Sounds like at an idle it wasn't producing as much as was being used, heated grips use a lot of current Had the same issue last year on my '99 RSV, barely able to push 11v at idle & 12.5v at 2,000 RPM with all accessories turned off. Ended up putting in a high output stator from Rick's, a bypass relay kit on the key switch that lead me to a slightly deformed (overheated) main power plug going to the ignition switch. No more issues now with charging at idle or on the road. 1
BlueSky Posted September 28, 2023 #10 Posted September 28, 2023 I think most motorcycles produce little current while idling. Letting it idle for 1.5 hrs is enough to drain the battery. Remember the headlight is on and sucking lots of juice. It's typical I think or that has been my experience.
