Goris B Passchier Posted August 11, 2023 #1 Posted August 11, 2023 I am looking for the location of Bank Angle Sensor Emergency Stop Switch location on my 2007 RSV. I tipped the bike over 3 weeks ago. This seems to be my last resort. Any help would be appreciated. Pics would really be appreciated. Thank you.
XV1100SE Posted August 12, 2023 #2 Posted August 12, 2023 (edited) Can you give a description of what is happening? Bike won't start at all? When you turn the key do the lights come on? Engine crank at all? You sure the kill switch isn't on? With kickstand up or down? When you turn on the ignition does the fuel pump click? Good write up on ignition switch issue - https://venturers.org/Tech_Library/index.php?action=article&cat_id=002007&id=339 Wiring diagram - Top right of the Venturerider.org window is a magnifying glass (search). You can do a few searches to narrow down the issue. Edited August 12, 2023 by XV1100SE
XV1100SE Posted August 12, 2023 #3 Posted August 12, 2023 From the electrical parts list - item 58 - shows to be in the left lower cowl. https://www.partzilla.com/catalog/yamaha/motorcycle/2007/royal-star-venture-xvz13tfw/electrical-1
