Vickersguy Posted July 9, 2023 #1 Posted July 9, 2023 The MKI Venture is known for " chirping ". There are lots of opinions and locations for the various chirps. The speedo cable chirps, the clutch chirps and some folks find a chirp from - who knows where... I think I found the answer for one source of the noise. A few years ago I adjusted the valves on my '83 and was surprised at how out of spec they were. I dutifully followed the clearances in the manual and put about 260 miles on the bike. The motor had a screaming chirp at 3500 rpm and it was audible other rpm's as well. Then "stuff" got in the way of riding for a couple years. Now I'm back. I was never happy with the chirping sound and went back to the manual and my notes and gave them a good inspection. I decided to redo my valve adjustment to see if somehow I screwed it up. Got the covers off and all was as I set it. So where did the chirping around 3500 rpm come from ? Did I have a plugged oil line or something ? I went back to the valve clearance tables and suddenly I saw it. The intake valve clearances are looser than the exhaust valve clearances in my factory manual. Really ? I checked on line for later models and this is not the case. So in my YAMAHA Factory Manual the intake and exhaust clearances are reversed. I redid the whole thing and POOF, all the chirping is gone. It also explains one common thing I see on engines offered for sale on e-bay where they explain that the compression is bad on an engine with only 40K miles. If you've got a chirp from the top end, check your valves . Just a head's up. 2 1
