I have a new gel battery for my ride (83 venture) they said all I had to do was ground the wire for the warning light and it would stop flashing ,it doesn't .we even tried grounding to the battery and still it flashes ,can anyone help with this problem .:confused24:
Not sure where the info is on this.
Did you check the Tech section?
I shorted the ends of mine when I changed batteries a few years ago but I read later after I came here that the guys were using a resister to short the ends but I don't remember the value.
Sorry, maybe someone else will show up soon with more intelligence then me.
Jerry
Do NOT, hook the wire Directly to 12 volts, UNTIL, you install the Resistors. !!!!
12 volts on this wire with burn up the computer !!
I went to radio shack got bolth size Resistors when i got my bike but it didnt work for me. I live with the red light.
You might want to try it again, Mike. I did the same thing as far as getting both value resistors. One worked (I don't remember which, I've slept since then:rotf:) and it was really easy.
