Rogerbartell Posted July 5, 2023 Share #1 Posted July 5, 2023 anyone have any ideas ? i been trying to find the fuel pump relay but no luck Link to comment Share on other sites More sharing options...
RDawson Posted July 5, 2023 Share #2 Posted July 5, 2023 Check the tank vent and fuel pump points. 1 Link to comment Share on other sites More sharing options...
mjsedlacek1 Posted April 20 Share #3 Posted April 20 I had this issue with my venture. It turned out to be the ignition switch. Bike would run, and once the polymer inside of the ignition switch would get hot, the contacts would lose connection and shut down. Installed a relay, bypass and ordered a new ignition switch. Link to comment Share on other sites More sharing options...
Du-Rron Posted April 21 Share #4 Posted April 21 Does it die because it has no electrical power? Check all wiring and grounds by wiggling them to see i connections are loose. Possibly an add-on ignition relay problem like mine was. Click Here To See Ignition Relay Problem & Repair Does it die because it runs out of fuel? Fuel Pump after your 10 minute time period, should be clicking upon restart. If not, check fuel pump points. Link to comment Share on other sites More sharing options...
