Guest gotsnow Posted June 1, 2008 Posted June 1, 2008 Got a 1989 Venture. While driving, if I loosely hold or let go of the handlebars, I get a terrible shake in the front wheel that would dump the bike if I continued to let it shake. I had the front wheel balanced and the front end checked but nothing. Got a dunlop 3 on the rear and a dunlop 2 on the front. Any help? I am leaving for British Colombia on June 18th. Thanks
Guest mmmouse Posted June 1, 2008 Posted June 1, 2008 Mine did that till I replaced the tire. Haven't had a problem since.
GigaWhiskey Posted June 1, 2008 Posted June 1, 2008 check the tire for cupping and the air pressure. if tire pressure is good and no cupping, might be a bad tire on the inside.
lonestarmedic Posted June 1, 2008 Posted June 1, 2008 I am going through this problem now. Got a lot of possibles. Gonna try and have the folks help me on the 21st in McKinney Tx. If I keep my hands on the bars all ok. I realize that is after your leave date but I am planning on lots of pictures and notes. JB
sarges46 Posted June 1, 2008 Posted June 1, 2008 Loose steering head will do this. Put her up on the center stand. Push handle bar over one way to the other the should go over and come back a little. Also sit down in front and pull on the wheel....it should be solid. See the tech articles in the 1st gen section tech section.
GeorgeS Posted June 1, 2008 Posted June 1, 2008 I added about 5 degrees of CW rotation, to the Steering head Nut on my 89, cleared up the Head Shake. Might be time to drain and refill the fork tubes with new Oil. You might be low on oil in one side. Check the Pinch bolts holding the forks in place, and the bolts holding the Fork Brace in place.
Guest gotsnow Posted June 2, 2008 Posted June 2, 2008 Oddly it only happens at slower speeds and I can feel it when I turn from a stop. I tried most of what you suggested, front tire inspection/ pressure, head stop torque, etc with no success. I will take it to a dealer today and probably have the front tire replaced. Thanks for all you help.
GeorgeS Posted June 2, 2008 Posted June 2, 2008 Did you try loosening the 4 pinch bolts, and the Axel, nuts, and the Brace bolts. The Add some torque to all of them, and tapping on everything, with a rubber mallet, to relieve any " Stress " , ie. make sure everything is aligned properly ?? Then retorque everything 2 or 3 stages. Might be worth trying. If that don't work, yes probably time for a new tire. Maby just needs balanceing.
