RDawson Posted June 13, 2023 #1 Posted June 13, 2023 May be a dumb question but I just did rear wheel bearings and a final drive seal with new gear oil. 10 mile test run and the final drive is too hot to touch, is that normal? I’ve never touched it after a ride before.
RDawson Posted June 13, 2023 Author #2 Posted June 13, 2023 Rode it back home and hit it with a heat gun, showing at 160*. After a little googling that seems normal.
uncledj Posted June 14, 2023 #3 Posted June 14, 2023 HMMMM..... I wouldn't have thought it'd be that hot. I'll have to check mine.
RDawson Posted June 14, 2023 Author #4 Posted June 14, 2023 51 minutes ago, uncledj said: HMMMM..... I wouldn't have thought it'd be that hot. I'll have to check mine. I’m interested to see your results. We’re leaving Thursday on a Florida trip, don’t want problems.
videoarizona Posted June 16, 2023 #5 Posted June 16, 2023 Ronnie, Sorry to see this late. Crossing fingers your Florida trip goes well That said, I've never seen my rear end get that hot. Did you align the rear drive using axle before tightening the 4 nuts on the pumpkin? Is the washer by the rear brake mount in the right place? Just throwing out guesses here? A hot bearing usually means things are too tight. 🤞 David
RDawson Posted June 16, 2023 Author #6 Posted June 16, 2023 8 hours ago, videoarizona said: Ronnie, Sorry to see this late. Crossing fingers your Florida trip goes well That said, I've never seen my rear end get that hot. Did you align the rear drive using axle before tightening the 4 nuts on the pumpkin? Is the washer by the rear brake mount in the right place? Just throwing out guesses here? A hot bearing usually means things are too tight. 🤞 David Strong storms killed the bike trip, we ended up driving the car instead. I put several miles on the bike Wednesday and the temps stayed down in the 120’s. Final drive was aligned at install, everything went together correctly, not sure what was going on. Everything sounded good, felt good, and it rode true. Head scratcher. 1
