amon Posted May 23, 2023 Posted May 23, 2023 Hi! Front left flasher doesnt run. All others are good. Its not the flasher itself. Both of position lights are ok ( blue wires) on front. I ear the relay working and the flasher signal on the computer is on when actionned. Excuse by advance my english is limiter on writting; for reading its ok.
XV1100SE Posted June 2, 2023 Posted June 2, 2023 Does it come on when you hit the four-way flasher? Probably not but had to ask. What about the running light? Is it just the flasher not working? Best way to trouble shoot it is to look for bad wiring. With an ohm meter check from the contact inside the bulb mount to ground to confirm your ground is good. Then check for voltage on the other terminals - you would have to turn the flasher on (and turn the key to Ignition/Start). If ground shows good, then trace the wiring back to the harness looking for a bad connection. Look at the link below to see the wiring diagram. Left flasher wire colours : B - Black - ground CH - Chocolate - left turn signal L - Blue - running lights
