GrahamLFCkeeper Posted May 5, 2023 #1 Posted May 5, 2023 So I bought a GL1500 a little while ago, it stuttered on acceleration, so began the fun... - The bike would start and run, but only ran well with the choke partially on - I removed the carbs and replaced as many Vacuum lines as I could get hold of (including the notorious 'under the mat' ones) - I sent the carbs to be 'sonic' cleaned - When the carbs were returned to me the choke (enricher) was the wrong way round, so I took it back and it was reassembled - Put the carbs back on the bike (took good pics so 99% certain its all correct) , pulled the choke to full (in 1c (33f) temperature outside) the bike wouldn't start - Turned the choke off, bike started, ran at 800 rpm, but would die when I touched at the accelerator - Its obviously getting far too much fuel (beyond a simple vacuum leak) I have two days as we have a long weekend (thanks to some man getting a crown put on his head here in the UK), any suggestions would be welcome. Thankyou in advance.
GrahamLFCkeeper Posted May 5, 2023 Author #3 Posted May 5, 2023 On 5/5/2023 at 5:00 PM, RDawson said: Checked the float levels? Expand That makes sense... especially as its only idling... I'll check them
