First of all I apologize if this was posted somewhere else.
I traded for a 1988 Venture Royale. When I got it I knew it had a throttle cable that was broken. upon inspection today I learned that the small junction box where all 4 throttle cables join with the cruise control cable was broken also ( one side is missing). Man its a tight fit in there. I have already removed the air box and the battery box. Is there a way to replace these without pulling the entire fairing off?
Remove false tank cover, left side lower and upper faring, radio etc, and the inside faring. The rest can stay. Cables can be tied together to work them into place.
I think that's it.
I think that's it.
Expand
cool. do you know where i can get an actual repair manual like a chiltons or clymer? all i find online are pdf files
I had one on disk and then later found the book on e bay. The files are all I have for my Victory. It works, you can either bring it up on phone or I print out what I need and take out to garage.
  • Like 1
