Doing my own tire change on 2nd Gen RSV, I used HF wheel weights on the rear wheel and frankly they stick out like a sore thumb. I'm not concerned as you can't see them behind the saddlebags anyway. The front tire is exposed. Has anyone found wheel weights that are not as obvious?
I use balance beads. They say to "pour them" in thru the valve stem, but that takes forever and then some. I mount tire, then break bead on one side if it dosent look like it will seat easily and pour them in. Been using them since 2008
