Help please. Vnture 83 . How to check if the class screen works. Where to connect + & -
 First off, make sure it's plugging in properly, then turn key to acc mode, screen should light up. If not you most likely have a cold solder joint that needs to be resoldered.
  • 5 months later...
Would you be able to share a link to a previous post or information on what needs to be soldered? I would appreciate it greatly. I have a full manual and can solder but not sure what i am looking at on the back of the boards.
