1BigDog Posted December 4, 2022 Posted December 4, 2022 If your removing your floats you will find those alignment supports in the way of removing the pin holding the float on two sides. A simple solution was to take a dremel and cut a notch into the support deep enough to clear the pin. Make sure you cover all carb openings including the fuel inlet before grinding. You can unscrew that idle adjustment screw for clearance. Don’t loose the spring. 2
