RDawson Posted November 17, 2022 #2 Posted November 17, 2022 Most common cause is the water pump seal.
Stormy1900 Posted November 17, 2022 Author #3 Posted November 17, 2022 Thanks I have it apart my question is I have read about this Twinkie thing in the v of the motor part of the breather it’s a cigar shaped o-ring can anyone explain this and we’re is located
RDawson Posted November 17, 2022 #4 Posted November 17, 2022 Look between the front and rear cylinders on the block. The heat exchanger/Twinkie sets there, it looks like a Twinkie earning it that moniker. There are o rings and seals that can let water/oil mix. 1
megamile Posted March 6 #6 Posted March 6 Oil in my coolant also; discovered 2 days ago. A lot of sludge. Ordered pump rebuild kit and seals but can find no info on twinkie including proper part name. Need seals and o-rings for it; can anyone help with name, part numbers, etc? 2011 Venture, 91,000 miles.
