Steve S Posted November 6, 2022 Posted November 6, 2022 Hello Forum. I'm trying to change my front turn signal bulbs on my trike to LED like the rear are and I need help locating bulbs. When I took the existing bulb out, I noticed it has 3 small pins on it to lock it in the socket. I have noticed it before but accepted it was a Yamaha "thing". Can LEDs be purchased to replace these? I have worked on cars since I was a very young man and have never seen this type of bulb used before, so I am interested in learning what the difference is. Thank you for your help.
PastorCurt Posted November 7, 2022 Posted November 7, 2022 See Blinker upgrade post further down in this forum
Marcarl Posted November 7, 2022 Posted November 7, 2022 13 hours ago, Steve S said: Hello Forum. I'm trying to change my front turn signal bulbs on my trike to LED like the rear are and I need help locating bulbs. When I took the existing bulb out, I noticed it has 3 small pins on it to lock it in the socket. I have noticed it before but accepted it was a Yamaha "thing". Can LEDs be purchased to replace these? I have worked on cars since I was a very young man and have never seen this type of bulb used before, so I am interested in learning what the difference is. Thank you for your help. Try Superbright LED. Google them. 1
Steve S Posted November 7, 2022 Author Posted November 7, 2022 (edited) 11 hours ago, Marcarl said: Try Superbright LED. Google them. I tried SuperbrightLED and they do not have LEDs with the 3-pin base. Could the sockets be replaced with 2-pin 1157 sockets and a load resistor be put in the line to make the lights flash properly? Edited November 8, 2022 by Steve S
Motorcycle Mike Posted November 7, 2022 Posted November 7, 2022 The only place I found replacement blinker bulbs was at partzilla. 1
