Hello Forum.
I took the trunk off my trike to do some wiring for new lights and found there were some serious cracks and holes in the bottom of the trunk.  I would like to replace it but I doubt I can find one that color so I will make a serious attempt to repair it.
Could someone tell me what type of compound make a good solid glue to bond the abs plastic.  I have used fiberglass cloth and resin with good success on boats in the past, but I'm not sure if this will bond to the plastic trunk.
Any help would be appreciated.
Steve
Have used the plastifix long ago and it seemed to work fine. It is a lot lighter than going with fiberglass (which does work) but is also heavier. I think adding more weight (depending on how big an area your talking about) can be counterproductive in the long run IMHO.  But then again, I’m no “expert”. Just sharing my own results.
I’ve had good luck dissolving ABS plumbing pipe in acetone making a glue or putty. Car stereo shops usually keep ABS sheets that can be cut and formed as patches.
I'm not sure that one makes a whole lot of difference from another. I fixed my 85 trunk with 15 minute epoxy on the road one year, just to get us back home. It never let go after that. Be sure to scuff the repair before adding the fix, I think that is the most important.
  • Like 3
I used abs cement and drywall tape, the mesh stuff to repair a crack 20,000 miles ago and it is still holding. The crack is visible from the outside since I didn’t do any body repair to it.
