megablok Posted September 1, 2022 Posted September 1, 2022 The turn signals of my 2006 RSTD have stopped working. I have checked the fusebox on the left side and the 15A fuse is intact. When I turn on the signals, I hear a faint "click" sound in the battery area the first time, but it does not make any sounds if I cancel the turn signal and turn it on again. I would appreciate any suggestions or similar experiences you may have had and how you fixed it. Thank you. -Morgan
Marcarl Posted September 1, 2022 Posted September 1, 2022 Could be the relay. Did you check the fuses with a multi meter, or just look at them?
