DNBoll Posted May 28, 2008 #1 Posted May 28, 2008 Well I finally finished the horn install & the cassette uninstall. I now have the perfect spot to store & operate my ipod. Dan (DNBoll)
yamahamer Posted May 28, 2008 #3 Posted May 28, 2008 Now Pop That Chrome Piece Off The Inside Of Horn And Glue It To The Top Where You Can See It. And Glue The Front One On Too They Will Pop Of Easy.
Eck Posted May 28, 2008 #4 Posted May 28, 2008 Looks like a very nice job ...does the cassette door operate like it used to? Oh, how about taking that thing out for a ride too once in a while... I noticed you didnt have any miles on it ... (I know.. I know..the key is off... I was only picking at ya..)
AZSpyder Posted May 28, 2008 #5 Posted May 28, 2008 Dan I have thought about removing the cassette too but seems like I read somewhere of a jumper or need to connect two wires together to get the audio system to behave. I haven't got around to sorting that out. Did you need to do anything to the wiring? Jerry
Gene-b Posted May 29, 2008 #6 Posted May 29, 2008 Come on man, were looking for some ansers here! I never use my casette player and I want a good place to keep my MP3:680:, this looks like it may just be the way to go. I want to see that in person! Gene
AZSpyder Posted May 29, 2008 #7 Posted May 29, 2008 Instructions are on the venturers site, under tech library. The CASS display even goes away on the control head! Jerry http://www.venturers.org/
bill04 Posted May 29, 2008 #8 Posted May 29, 2008 Did the same thing ,,,, anyone wants a used cassette player. Easy job and now at least I can use the free space for cell phone and my Mp3 player.
DNBoll Posted May 29, 2008 Author #11 Posted May 29, 2008 Yes the door works the same as before removal. Yes I did get the instructions off the "Other" site. No I did not use the hammer technique for the cassette disposal. I simply unplugged the auxiliary connection to the cassette deck and connected a short mini plug cable, 3' I think with a male plug on each end, & ran it into the space behind the door for easy access. Everything else seems to work the same. "Cassette" no longer shows up in the "screen" as a choice. Everything went the same as described (on the other site post) except I used an X-acto razor saw to remove (cut off) the back part of the cassette window to make the new opening a little larger & I filed all corners to make them smooth. You'll know what I mean if/& or when you get to that step. The complete process was not all that difficult it just took a little time. You need to take your time & do it right because when the door is open, your handy work will be seen. Thanks everyone for all the other Good & Cool Stuff on this site! "I Luv Ya Man!" Okay enough of that. Dan, (DNBoll)
DNBoll Posted May 29, 2008 Author #13 Posted May 29, 2008 Thanks Yamahamer, I did remove the one on the inside. I'll get out the glue. DNB
seforeman Posted May 29, 2008 #14 Posted May 29, 2008 I did the same thing - but installed and XM Radio in its place. I too have a used cassette deck for sale..but no cassettes to go with it. Maybe you could find some - at an antique store :-) Stuart
ventureblue Posted May 30, 2008 #16 Posted May 30, 2008 i want to do this MOD but i want to wait till i either find someone to help and then replace the windshield at the same time.
DNBoll Posted May 30, 2008 Author #17 Posted May 30, 2008 Splitting the fairing is not as hard as it seems. You do not have to split the fairing to replace the windshield so they can be completed at different times. Be extremely careful with that chrome trim piece at the base of the windshield. The tabs that hold it in place are very fragile. Easy does it in removal & reinstall. Be sure to read the posts on "splitting the fairing" & the one on the "other" site about removing the cassette deck. The only thing I did differently was I used a 3' male on each end cable. I did not use a splitter. One other thing you could do is to run a power cord into the space to keep your ipod charged. I did not. I thought about it after I had finished & put everything back together. Maybe next time. Good luck ventureblue!
