For us East Coast riders that live in the Northern part of the country, (except for those crazy Canuc's that seem to ride ALL year long!! LOL) it has been a LONG winter!
With temps starting to creep up, and flowers starting to pop out, it looks like spring is right around the corner. Which brings me to the point of this post. It's time to take a GOOD close look at your scoot BEFORE you head off into the wild blue yonder!
Tires: There is nothing between YOU and the road except two skinny pieces of rubber, my friend! Get down and have a close look at the two marvels of modern technology that keep YOU and THE ROAD separated. How's that tread look? Is the air pressure correct? What about the sidewalls, are there "cracks" in the rubber surface screaming that your tire needs to be replaced. Please don't ignore these signs that your tires need maintenance!
Air Filter/Filters: When was the last time you pulled the cover on your Air Filter? Is it caked with dust and to your surprise there are "critters" living in there? Your engine can't breathe if the Air Filter is plugged up. This effects gas mileage and performance. Show your scoot some love, and change out that filter if it has been a few years. As my wife would say, "I'm Worth It"! Well brother, your bike is as well!
Engine Oil/ Filter: Now, just because you only put 900 miles on your bike the last two years, doesn't mean you can change your oil and filter every FIVE YEARS! Engine Oil breaks down over time, and the result is the creation of acids that score bearings, piston walls and fog up the sight glass on the side of the engine. Most of us have a decent amount of money tied up in our motorcycles, so the cost of an oil change is money well spent, in my opinion. Please don't forget that our bikes have a "wet clutch" which means that the clutch pac and transmission gears are lubed with the engine oil. Oil for a CAR with Friction Modifiers CAN NOT be used in a Motorcycle, PERIOD! I can't stress this enough. You will send your clutch to an early grave if you put the wrong oil in your bike. Please be careful!
Brakes: As much as I like to go FAST, I always keep in mind that I also need to be able to STOP! Take a few minutes and remove all three brake calipers from your bike. That's right, I said REMOVE all three calipers from the rotors. (Leave the brake line connected!) There are only two bolts holding the caliper on the mounting bracket. I suggest you blow the brake dust off of the inside of the caliper body, check the condition of the caliper pistons and seals, (Is a piston stuck, are the seals leaking, etc.!) If the pads are thin, replace them. If you have a stuck caliper, or a leaky seal, the calipers can be rebuilt. Repairing a caliper is a LOT cheaper than replacing a BRAKE ROTOR! Not to mention the difference in stopping distance between a good set of brakes and a bad set might be the back window of a soccer mom's SUV! There are also performance upgrades in the form of R1 4 piston calipers that can be added to your bikes that give even better braking action. Don't take my word on it, look into it or PM me.
Fork Seals: Because the front "shocks" on our motorcycles are built into the lower fork tubes, there are two seals that keep the fluid in the lower fork tube, and not on our front brakes and wheel! If you see an oily ring around the chrome tube that comes out of the lower fork tube, then this means that the fork seal is starting to leak. There is a cleaning method to clear up a seal that is "seeping" a bit, but if that seal is leaking to the point that oil is dripping down the lower fork tube, then it is time to replace that fork seal. Now the skill level for this service is a bit higher than changing oil, and you might want to consult a local motorcycle repair shop, (NOT a Stealer, I mean Dealer) to take care of this project. It's best to be "Real" with yourself about your mechanical abilities with a job like this. But weather or not you do it your self, or have a repair shop do it, It needs to be done all the same. The money you will save in replacement brake parts if you have a bad leak will outweigh the cost of this service, in my opinion.
Clutch: Next to the "Oil Debate" is the "Which Replacement Clutch Do I Use" Debate. I am not even going to address that issue here and now, BUT if you drop your scoot down a gear and roll on the throttle to pass a semi truck on the highway, the LAST thing you want to hear is the motor winding up, and your bike NOT going forward in a hurry!! Let me repeat that! If you try to pass, and your clutch is slipping, then you need to address this issue, PRONTO! I personally believe that the BEST tool that a motorcycle rider has is the ability to avoid and evade a dangerous situation. Bar None! If I "drop the hammer" on my scoot, it's because I need to be somewhere else at that moment, because if I'm not outta' there in a hurry, I'm in an accident. Clutch slippage is NOT an option for me, and it shouldn't be an option for you either. Please address ANY clutch issues BEFORE you actually need your bike to get outta' there quick.
Lighting: Let's be honest, NOT replacing burned out light bulbs is just plain TACKY! But on top of that, it could create a safety issue with your visibility! As motorcycle riders, we have always had an issue with BEING SEEN! I can't tell you how many motorcycle accidents I have heard about and the first words out of the cage driver's mouth have been, "I didn't see that rider" before I ran over him, then backed up over him! (Just Kidding) Make sure ALL of your lights work, and even explore some new technology like LED Headlights or other types of accessory lighting. It may save your life!
Now there are other things that you should be looking at on your scoot, but this list will give you a good starting point. The point I am trying to make here is "Look you bike over the way you looked at your Girlfriend/Boyfriend, Wife/Husband ON YOUR FIRST DATE! You didn't pull the trigger on that project without giving him/her a good "Once Over" , (Let's hope not anyway) So since everyone on this forum claims that their scoot's are their "Second Love", then don't disrespect your bike by not taking good care of her. My dad used to say, "If you take care of your bike, Your bike will take care of you! Ride safe out there!
These are MY thoughts, for what they are worth.
Earl
  • Like 6
Not just you Nor’easter folks. I had one of my firefighters show up to work on a Harley fresh out of storage a few years ago with 12lb in the rear and the front didn’t even move the gauge.
  • Sad 1
Always a great reminder of good advice. Maybe even more so for seasoned riders since we sometimes get to comfortable and overlook whats important.
BTW who you calling crazy?
  • Like 1
  • Haha 2
Don't know him from Adam
  • Haha 1
  • 1 month later...
Found another one😱. I was at the boat ramp last week when a young couple pulled in on a Ducati with a near flat front tire. No gear, no helmets. I flagged them down and pointed it out, his response:  “ I thought it was feeling a little weird”. 10# by a gauge.
  • Sad 1
  • 10 months later...
