goldwing trike Posted April 13, 2022 Posted April 13, 2022 my 2008 gotd wing with voyager trike kit ,the tail lights and brake lights have quit working also no power for the trailer hitch plug in.
Marcarl Posted April 13, 2022 Posted April 13, 2022 You might have blown a fuse maybe due to a chaffed wire. Check the fuses and then check the wiring for bare spots,,, or maybe a mouse chewed through the wires.
goldwing trike Posted April 13, 2022 Author Posted April 13, 2022 where are fuses located for thike kit on my goldwing
Marcarl Posted April 13, 2022 Posted April 13, 2022 18 minutes ago, goldwing trike said: where are fuses located for thike kit on my goldwing Try under the right side cover under the seat. Carefully and gently as possible pull and tug on the cover to remove it. It's held in place with plastic pins and grommets.
