I'm on my 4th set of passenger headsets in 4 years. The drivers set which gets used all the time doesn't break.
Could there be something in my wiring burning these out?
Last ones were IMC-HS-G35U-FIVE PIN OPEN OR FLIP FRONT HELMET HEADSET.
I don't know of anything on the bike that could be causing it. Does it happen while in use or do you just plug them in and find that they no longer work?
My J&Ms have been good for over a year since I got them but my wife doesn't ride a whole lot, maybe 2 dozen times. I don't know if all are alike but mine have a connector maybe 6 inches from the headset. She plugs just the lower cable into the bike before getting on. Once in place connects the upper plug. If whatever type you were using just had the one plug for the connection to the bike it could have stressed the cable trying to plug into the hard to reach connector while seated. Just a shot in the dark not knowing how it was done.
Jerry
