Pasta Burner Posted March 10, 2022 Posted March 10, 2022 @saddlebum so the piece between the padded peg and the flip up joint is longer than normal? I’ve got short legs and the lower wind deflectors so I need to mount them close and wide. Should be delivered Monday
saddlebum Posted March 10, 2022 Posted March 10, 2022 (edited) 11 hours ago, Pasta Burner said: @saddlebum so the piece between the padded peg and the flip up joint is longer than normal? I’ve got short legs and the lower wind deflectors so I need to mount them close and wide. Should be delivered Monday Yes they are by about 2" longer. You can get them in 3 different lengths if I remember and they are easy to swap out you simply undo the Allen bolt in the pad remove the short adaptor and replace it with the longer one. You can find all sorts of configurations as well on thier web site https://www.kuryakyn.com/category/42/highway-cruise-pegs Edited March 10, 2022 by saddlebum 1
