84VentureMatt Posted October 4, 2021 Posted October 4, 2021 I drive OTR so the trucker in me has a addiction to lot's an lot's of LED lighting . I have been scrolling through but have not found a topic on this yet . I am looking at adding Fog Lights to the front then rear and side marker amber an red lights seeing my 84 has been very well kept i feel the amber/ yellow lighting is the best color to match my tan an cream color paint .....I was told earlier that a bike looking like a spaceship is annoying but my response to that is Hey you saw it and you remember it so High visibility worked in my opinion . I do not want to drill holes in my hardbags so alternative mounting will be my route but a really nice glow around the bike from behind plus I am going to add like a 4" yellow fog lamp to the crash bars so forward lighting should be burn the hair off a opossum at 100 yards worthy ........so who has lighted up their bikes recommendation of lights mounting locations is welcome also toss some pics in lets see these light up the night sky rides
videoarizona Posted October 16, 2021 Posted October 16, 2021 (edited) You can buy led panels that replace the side reflectors. Just take off the reflectors and bolt on the lights. The led panels I found fit almost perfectly inside the reflector mount. Just slight trimming. I wired mine to the running lights and turn signals. Get the LEDs that offer two different led sets per light....IE three wires. Ground. Running and turn. This way they also blink with turn signals. I also added a white led strip under the cowl wired to the running lights. Finally, added a set of lights to the rear reflector in the center and one bulb to the reflector on each side in rear underneath the hard bags. Pics show result.... The reflector on the trunk is very bright with headlights on it so I left that alone. Edited October 16, 2021 by videoarizona Clarify 1
Pasta Burner Posted October 16, 2021 Posted October 16, 2021 @videoarizona interesting your trunk doesn’t have lights. My 87 has running lights and turn signals on the trunk, I guess there were different options. I like that you have the radiator side cover light working. Mine had the wires cut and I haven’t bothered to hook it back up, but seeing yours I think I want to invest the effort. Do those also blink?
84VentureMatt Posted October 17, 2021 Author Posted October 17, 2021 @videoarizona your bike looks great ..mine is an 84 so I have the small hard bags never had a side light option on them but i am going to try an find those led reflector replacement lights for sure 1
videoarizona Posted October 17, 2021 Posted October 17, 2021 Similar to this... https://www.amazon.com/Anauto-Universal-Motorcycle-Rectangle-Reflector/dp/B078MWTSB1/ref=asc_df_B078MWTSB1/?tag=hyprod-20&linkCode=df0&hvadid=507584275636&hvpos=&hvnetw=g&hvrand=15848677558438273970&hvpone=&hvptwo=&hvqmt=&hvdev=t&hvdvcmdl=&hvlocint=&hvlocphy=9029980&hvtargid=pla-935117818219&psc=1
84VentureMatt Posted January 11, 2022 Author Posted January 11, 2022 On 1/9/2022 at 4:40 PM, MoonShine said: @MoonShine now thats a really kool and clean install right there looks great 1
UK_in_NY Posted May 16, 2022 Posted May 16, 2022 Some good ideas here. My 83 has ALL the Drag specialties accessories which ALL have lights in. The rear is something silly like 12 lights. I did try to add LED bulbs but it is going to need some electrical work to make that work. My snow plow (belly pan) is currently being powder coated and I will be putting LED's in that when it comes back.
