Dutch Navigator Posted September 20, 2021 Posted September 20, 2021 (edited) Does anybody know if these mufflers will fit? They have a 45mm en 65mm mounting end. Partnrs. OEM 64900240 en 64900239. Peter Edited September 20, 2021 by Dutch Navigator Typo
Squidley Posted September 20, 2021 Posted September 20, 2021 They should fit, I don't believe HD changed much on their big bike mufflers in the last 15 years. I have a set of slash cuts from a 2005 Road King on my RSV. You'll have to get a special clamp that will adapt from the metric pipes to a HD muffler. I know their is some posts about it on the site, You'll just have to do some searching. 1
Dutch Navigator Posted September 21, 2021 Author Posted September 21, 2021 Thanks! I read some info about the clamps. 1
videoarizona Posted September 21, 2021 Posted September 21, 2021 Yep. Have a pair on my RSV.. Yes, the do sound good. And yes, you will need to get the clamps. 2
djh3 Posted September 23, 2021 Posted September 23, 2021 I went cheap and used hose clamps. Aint pretty but worked. Only thing on the HD pipes was there was a couple years there they had a Cat in one side. Somewhere around 2009 ish I think. 1
Dutch Navigator Posted September 23, 2021 Author Posted September 23, 2021 Thanks for mentioning this. I have to check that. These pipes are from 2017. OEM-number says 'no Cat'.
BratmanXj Posted September 24, 2021 Posted September 24, 2021 Also there should be drawings on the internet for the fabricated metal brackets to fit HD mounts to the Venture mounts. Some guys have used P-clamps around the saddlebag brackets with good luck too. 1
videoarizona Posted September 24, 2021 Posted September 24, 2021 Someone on this site made brackets. There also was a diagram with info on building your own. I thought I just saw a post recently???? Memory...first thing to go as we age....LOL! 1
djh3 Posted September 24, 2021 Posted September 24, 2021 I just use 3/4" P clamps from home depot and a couple 1/4"x20 bolts in the HD factory bracket. Making those hockey stick bracket was going to be a day project. Once I checked into it the P clamps were easy and cheap. 2
Dutch Navigator Posted September 26, 2021 Author Posted September 26, 2021 I found the drawings of the brackets, thanks guys! 2
BratmanXj Posted September 29, 2021 Posted September 29, 2021 On 9/24/2021 at 6:46 PM, djh3 said: I just use 3/4" P clamps from home depot and a couple 1/4"x20 bolts in the HD factory bracket. Making those hockey stick bracket was going to be a day project. Once I checked into it the P clamps were easy and cheap. Brother-in-law works in a machine shop and I'm an engineer with AutoCAD.... gave him a scale drawings and had brackets the next day. 2
