Installed Barons rear lowering kit, now when I hit a bump bottoms out on the tire. Got score marks on the tire. Any suggestions?
Thanks...
Dragline
Thanks Squidley, I didn't want to over do it with the air pressure, do you know what the max pressure is, I don't want to blow the seals, if that's possible.
  • Like 1
I'm not positive, but I believe the max is at 50 or 55 lbs. I'm sure others who have an owners manual will chime in.
Thanks Squidley, I don't have the owners manual.
I have a Clymers Shop Manual but I could not find the air pressures for either front or back. I put it just under 25 psi and it still hit a couple of times on today's ride. Between the wife and me we're over 400 lbs so I quess I better pump it up about 10 psi more, or go on diet.
  • Like 1
That link that I provided can be downloaded to your phone or computer, it's a pdf file and is the complete owners manual.
Does anyone know if the rear shock can be repaired with new seals , or does it have to be replaced? Only holds air for a day or two.
