i spent  many months going over the bike front  to back  Repair .....Forks , Steering head , brakes , Changing system (New Stator ), new tires  102 70 R18 on the front  ,,,Removed faring , removed rear Trunk , removed 65 lbs  ,, Installed a back rest at the rear ,,I moved all the relays to under the seat ,,, I repined the center shock by 1/2 ., to raise the rear wheel and lower the bike by 1 1/2 inches ...My feet are flat on the ground ..I have 5 inches clearance about the rear wheel and 5 inches of ground clearance at 15 PSI on the rear/center shock  20 psi will increase the ground  clearance to 6 inches  ,,,still lots to do , I need to find a better place for coolant recovery can ,, then repaint the bikeIMG_0089.thumb.JPG.3707660e5e39f1fe112b636d8327d528.JPGcrease the ground IMG_0072.thumb.JPG.dc25a459d6b2afdb6e5551c2c0b76a2a.JPGto 6 inches .IMG_0084.thumb.JPG.46f0057267039a15a6983c1bed82f91e.JPG
  • Like 5
