So I have a small leak, thinking it's my middle drive gear seal? more to come later on help, but want to verify.
is there a problem in dumping a vial of this in the oil of my 83?  Just want to make sure before I cause harm
https://www.autozone.com/test-scan-and-specialty-tools/uv-light-and-accessories/p/autopro-multiple-use-leak-detector-uv-dye-oil-atf-ps-fuel-1-oz/667635_0_0
or Ebay
thx
Most dyes for leak detection are safe We use at it at work all the time for oil, AC and diesel fuel leaks. just make sure the dye you use is for the type of fluid your dealing with and yes most are very safe to use. Personally I have not come across one that is not ( and we use them frequently at work )as long as you use it properly. Example do not over use and do not use dye intended for AC systems in lubrication systems or visa versa.
  • Like 1
