Free to Ride Posted August 3, 2021 Posted August 3, 2021 Good morning. Any idea where to buy: 1NL-25830-52-00 Disk Brake Ass''y (1Nl-25830-51 1NL-25830-51 and 1KT-W0047-00-00 calliper ? Thank you.
Squidley Posted August 3, 2021 Posted August 3, 2021 Your best bet will be to try and find it on ebay or put an ad in the wanted area of the classifieds.
cimmer Posted August 4, 2021 Posted August 4, 2021 Are you looking for a rotor and caliper? Ebay is a good choice but be prepared to rebuild the caliper before using it so you know you have a good one. Rick F.
saddlebum Posted August 4, 2021 Posted August 4, 2021 11 hours ago, cimmer said: Are you looking for a rotor and caliper? Ebay is a good choice but be prepared to rebuild the caliper before using it so you know you have a good one. Rick F. Just don't split the housing unless your very confident. the o rings that seal the housing halves can be difficult to acquire. I do split them because it makes it easier to clean but it is very important if you do that you have the proper o-rings and reassemble them exactly. 1
skydoc_17 Posted August 7, 2021 Posted August 7, 2021 Hey Avi, Yamaha no longer offers this Semi-Floating Rear Brake Rotor new unfortunately. EBC offers a new Bi-Metal Semi-Floating Rear Rotor for the 87'VR. I sell them for $250.00 and $10.00 to ship. You may be able to find them cheaper somewhere else. I buy direct from EBC, but the low volume I purchase doesn't bring me much of a discount. I also have a used rear caliper from a 1987 Venture. I would suggest a rebuild on this caliper, but it did come from a functioning 87'VR. You might have luck just putting it on. (BUT I do suggest that you rebuild it!) If I can help you with either of these parts, or a rebuild kit for the caliper, just let me know. Even if you get these parts somewhere else, I wish you good luck with this project! Earl 1
