I've been reading the posts on modding the cassette.  I just want to replace mine.  I was able to remove the old deck because the cover was broken.
I can't get the replacement deck in because the door will not fit through the inner fairing opening.  I've measure it and it is taller than the opening.  I've tried it with the door closed and open without any success.  Has anyone found the trick to this?
I solved the problem.  I had to take the inner fairing loose and lean it forward to get the cassette back in place.  Not an easy job and I don't recommend it.
  • Like 1
  • 2 weeks later...
