  • 2 weeks later...
On 6/21/2021 at 2:53 PM, videoarizona said:
Confirming the fuel lines are 5/16id for the RSV?
Also, is that the same size for the carb drain?
TIA,
david
Obviously you found a gap in our collective memories. Buts there's hope Dad will likely right a software patch soonish:think:
photo of thinking man statue
Looks like it, grins!
Doesn't matter. I couldn't get my big hands between the carbs enough to push on either of the 2 sizes I brought  with me. So didn't get to drain the bowls and check the levels.
For the bowl drains, I used 1/4" hose.  No way to get your hands up in there.  The hose I used is stiff enough that with a little patience and practice can guide it to the drain port then slip it on with a little gentle pressure & twisting motion.  IIRC, a 5mm allen key opens the drain port.
  • Like 1
