Make sure to use a screwdriver that fits the screw heads properly. These screws are very soft and the heads will strip out very easily.
Make sure to check for corrosion as moisture can get in under the lense and cause bulb to lose contact.
The JIS japanese version of the philips screwdriver made by Vessel and available through Amazon is the best screw driver I found for the screws on these bikes the  flute tapers and angles between the japanese (JIS) screws and the philips differ slightly and is why a normal philips screwvdriver will cam out so easily. The (JIS) even works better on the philips screws than the philps screw driver does. Thier grey handled impacta line is great for breaking loose tight screws without rounding them out.
FROM AMAZON CANADA.
https://www.amazon.ca/Vessel-Megadora-2x100-Screwdriver-930-2-100/dp/B000W9KWF2/ref=sr_1_8?dchild=1&keywords=vessel+jis+screwdriver&qid=1624197256&sr=8-8
https://www.amazon.ca/s?k=vessel+JIS+screwdrivers&ref=nb_sb_noss
FROM AMAZON USA.
https://www.amazon.com/Vessel-Megadora-2x100-Screwdriver-930-2-100/dp/B000W9KWF2/ref=sr_1_5?dchild=1&keywords=Vessel+JIS+screwdrivers&qid=1624197497&sr=8-5
https://www.amazon.com/Vessel-Megadora-Impacta-P2x100-Screwdriver/dp/B003BI8HHQ/ref=sr_1_16?dchild=1&keywords=Vessel+JIS+screwdrivers&qid=1624197633&sr=8-16
Edited by saddlebum
  • Like 1
